Reload this Page >
T-one models F22A Raptor scale build!!!
Old 03-28-2019, 06:53 AM
  #201
gunradd
My Feedback: (9)
gunradd's Avatar
F22 pics by Andrew Griffithpics from FLjets. Notice the rudders on knife edge!
Unfortunately this was after a bolt backed out on the gear and caused me to have a gear up landing that took the inboard main doors off. The factory will be using loctite on the production planes since you can’t get into this bolt with the gear installed so it needs to be done before hand.
gunradd is offline
Old 03-28-2019, 05:48 PM
  #202
gunradd
My Feedback: (9)
gunradd's Avatar
Some good video from my friend Paul.
gunradd is offline
Old 03-29-2019, 04:55 AM
  #203
TonyBuilder
TonyBuilder's Avatar
Nice...
TB
TonyBuilder is offline
Old 03-29-2019, 05:25 AM
  #204
skunkwurk
My Feedback: (18)
skunkwurk's Avatar
Job well done, Chris! Another winner.
skunkwurk is offline
Old 05-16-2019, 11:21 AM
  #205
gunradd
My Feedback: (9)
gunradd's Avatar
Good news guys!! The factory are just about done with the molds! They sent me some sneak pics. They will be making F22s starting next week!
gunradd is offline
Old 05-16-2019, 12:17 PM
  #206
Digital Pilot
Digital Pilot's Avatar
There we go!!!!! Nice!!!!!
Digital Pilot is offline
Old 05-16-2019, 12:20 PM
  #207
FenderBean
FenderBean's Avatar
Gun I thought this was already a done and was making models already?
FenderBean is offline
Old 05-16-2019, 12:29 PM
  #208
David Jackson
My Feedback: (15)
So, can we expect shipping to take sometime in August? Gives me a bit more time to complete other projects and get the old credit ready to pay the balance due.
David Jackson is offline
Old 05-16-2019, 01:21 PM
  #209
Len
Len's Avatar
Outstanding!!! The JL F-22 is almost re-engined (P-180NX) and ready to hone my skillset this summer, in advance of the T-One’s arrival...
Len
Len is offline
Old 06-21-2019, 12:19 PM
  #210
Mikey5547
Any pics of updated kit?
Mikey5547 is offline
Old 06-21-2019, 04:31 PM
  #211
gunradd
My Feedback: (9)
gunradd's Avatar
Yep they are making production models as we speak.
gunradd is offline
Old 06-21-2019, 06:37 PM
  #212
FenderBean
FenderBean's Avatar
Yelp Dirk said they were pulling from the molds already, damn even sexy in white gel coat
Old 06-22-2019, 07:10 AM
  #213
Mikey5547
looking sweet!
Old 06-22-2019, 07:50 AM
  #214
David Jackson
My Feedback: (15)
Got notification May 31, that the internals were being installed in my F-22. Looking forward to receiving pictures of the painted plane.
Decided to go with a single engine installation. Is anyone planning to install a K-320?
Old 06-23-2019, 12:26 AM
  #215
Looping31
Looping31's Avatar
Wonderful !
Waiting for mine this summer. Ordered 2x Merlin 166 for this beast.
Can't wait ;-))
Arnaud
Looping31 is offline
Old 06-23-2019, 04:00 PM
  #216
gunradd
My Feedback: (9)
gunradd's Avatar
pretty sure that would be to much and it’s not needed. Also don’t think it will fit because of the lower bomb bay doors
gunradd is offline
Old 06-23-2019, 06:18 PM
  #217
David Jackson
My Feedback: (15)
Chris,
Appreciate the info.
Old 06-25-2019, 02:07 AM
  #218
Looping31
Looping31's Avatar
Hi Gunradd,
I'm sourcing equipments for my F22 coming soon and have a question please.
How many electrovalves do you need
-for the gear ?
-for the gear doors ?
Concerning the fuel fitting (bulkhead insert, clunk..), is it included in the kit ?
Thank you.
Old 06-25-2019, 05:40 AM
  #219
gunradd
My Feedback: (9)
gunradd's Avatar
Originally Posted by Looping31
Hi Gunradd,
-for the gear ?
Thank you.
Fuel tank fitting I'm almost positive is included but I like to plumb mine differently so I had to order another vent. I never use T fittings I'm my fuel setups so in the forward main fuel tank I used 2 vent fittings that the saddle tanks feed into. I also used to vent lines from the saddle tanks with separate vents no T fittings. That is just how I do things and I guess might be over kill but I don't take chances on the fuel system.
For the gear...…
It depends on what you use. Dirk sells a gear controller and valves that will do the gear/doors/brakes/canopy all in one unit including the valves. This system was not completed when I got mine yet so I had to use the gear/doors and brakes valve with separate canopy/canopylock/bomb doors open/close.
If you are doing all seprate valves it would be
gear open/ close
gear doors open/close
brakes single action
canopy open/close
canopy lock open/close
I would highly recommend getting the valve Dirk sells to clean up the install and have failsafe built in. I do think you are one valve short though with the big one Dirk sells so you would need one extra valve I believe.
gunradd is offline
Old 06-25-2019, 05:44 AM
  #220
gunradd
My Feedback: (9)
gunradd's Avatar
Here is the air system I would use. You would need to call Dirk to get the price I'm not sure. Also keep in mind your still one 2 way valve short.
https://pacificrcjets.com/collection...ighting-system
gunradd is offline
Old 06-25-2019, 07:15 AM
  #221
causeitflies
causeitflies's Avatar
What ever happened with the onboard air pump?
causeitflies is offline
Old 06-25-2019, 07:30 AM
  #222
gunradd
My Feedback: (9)
gunradd's Avatar
I have it and it works great. Only problem I have with it is the pressure out line gets to hot if it runs to long and gets soft. I need to source a better line for the hot air. But it works good as is I just don't let it charge up all 3 air tanks from empty.
gunradd is offline
Old 06-25-2019, 07:59 AM
  #223
FenderBean
FenderBean's Avatar
Im expecting mine to be done in the earl fall, doing twins 166Ts on it like that F-18. I got a feeling its going to show up about the time I start my new job which will put things on the back burner for a bit. Will be a great winter project!
Old 06-25-2019, 06:48 PM
  #224
cycross
cycross's Avatar
Considered using a teflon tube to interconnect with the pump and then a Festo quick connector back onto the regular festo air line? That will eliminate the hot nipple heat conduction issue.
cycross is offline
Old 06-26-2019, 11:37 PM
  #225
Doug Cronkhite
My Feedback: (34)
This airplane has an amazing presence in the air. Can't explain it any other way. If you keep the speed down, it's really hard to distinguish it from the real one..
Doug Cronkhite is offline
