Sig Kougar Build
#226
RE: Sig Kougar Build
I've got a buddy who has said he will give me a brand new rear exhaust OS 61 though I'm not sure which one it is. Hopefully I'll pick it up this Sunday.
Bill
#227
Dan, I've used the solderless tubes a number of times and I believe they are the most well thought out method to date. Pete Peterson has come up with one of the best ideas for E.P. flyers.
I intend to get some A-123's and will use his power tubes to make up my packs.
Don't forget to get the silver paste.
cheers jollyroger
cheers jollyroger
#229
CA
Went out again yesterday and my buddy happened to have the engine on him. It's an older OS Max 61 V. Very heavy engine...I've got to do some research on it. He said I could have it if I put it in that engine, I can get around prop clearance issues by going to 3 blades. I did that with one of my other Kougars that had a Fox 50 in it.
My concern is that this engine is rather dated and very heavy.
#233
CA
I don't have the budget for a Jett or a Nelson - simply put.
I'm not looking for a speed demon and frankly I should leave this one be, but he gave me the engine so what the heck.
#234
So it depends upon what you want to accomplish. Heck I have a Kougar that is a pound overweight and it flies very well.
Bill
#236
Helitb, try this one. the dimensions are mixed up on Tower, hight and width.
I had to buy a second one when I built my Kougar, I broke the visor so I had this one to be able to look it up. Basically, any 1/8 scale pilot should fit in case you don't want the military pilot.
http://www3.towerhobbies.com/cgi-bin...p?&I=LXPZH5&P=
#238
My Kouger flew with an O.S. Max Blackhead.60, Prop clearance was not a problem with 11X7 props. Nor was balance, however, I don't place the servos until the airplane is almost ready for test flight and use them and the battery to help with balance. My Kouger was a fun airplane! The .60 maybe gave better vertical. The addition of a .60 certainly isn't a new idea. Almost as sson as SIG introduced it people started putting .60s in them.
#240
Thanks for the information. I haven't done much with the Kougar over the last few weeks. I do have a question.
Question:
1. What's the best way to line up the motor mounts and mount the engine? The manual shows the older style and the newer style is wider so the dimensions in the manual won't help much.
Question:
#241
My Feedback: (13)
As for what jet pilots fit under a Kougar canopy... I picked up this little guy at Toledo a few years ago. Don't remember the vendor... but I've seen him before. Know all those nicely painted pilots of all sizes that Hobby Lobby offered? They all had names? This one was Tom, I believe. I had one of those in an EZ Dago Red back in the early 90s. Saw this one, and realized he would go perfectly in the Kougar.
Anyway... I had to trim some of his shoulders, but otherwise he goes in very nicely. My Kougar is totally stock, built exactly per the book.
Hope the photo comes out; I've got a new 'puter, with Vista, and I'm still learning its quirks...
#243
My Feedback: (13)
Ya know, this thread got me all cranked up about the Kougar. I pulled it down off the wall to get that pilot picture, and ended up cleaning the quarter-inch of dust off the thing. She's plugged into the Alpha 4 now; weather permitting, I'm gonna fly the little beast tomorrow. Been over a year since she took wing.
Here's another view...
#244
GA
ORIGINAL: DBono99
125.00 for batteries!!!! NO noise, No smell, No mess to clean , but most importanly NO dead sticks..try It u'll like IT..
An electron well can run just as dry as a glow fuel tank. Empty is still empty unless the laws of physics have changed since I got my degree.
- Jan
#245
Steve...Thanks for the tip on the pilot. I actually did a little work on the Kougar this weekend. Once I finish up my two on-line classes I will have plenty of time.
#246
NJ
Klaatu. Believe me once you go Electric, glow will be just a distant memory..LOL
I've got 12 glow planes all ready to go, haven't flow any of them in awhile..My last 5 planes have all been Electric. Most have been downsized version of my glow planes..
Here are some pics of my E planes..
Thanks Dan
PS any body wanna buy 40 size glow planes ready to go???
Thanks Dan
#247
MO
Well i have read all of the post and i guess i should have read the closer than i did because you guys were right this is not a good one to start off with but this post has helped me get alot closer to getting it finished so here some pics of what i have got done so far does anyone else have any more pics of there stuff done or working on it i would like to see more to make sure i get everything done right
#249
iliketwinkies...It looks pretty good to me. This plane is my first build as well. I'm about a step behind you. I have to mount the tail parts one day this week.
