JetCat P400-PRO glows red with abnormal temp.
Hi, I have a JetCat P400-PRO engine which I bought last year but I just got the chance to run it recently. I used paraffin with 5% of BP2197 turbine oil which meets MIL23699 standard. The first time I turn it on the exhaust nozzle glew red and the temperature in GSU shows above 850C. I was worried if my engine got overheat so I decided to pull the plug before the engine reaches its idle speed. Can anyone tell me if that's normal? By the way I live in Indonesia with air temperature of 30-32C when I tested the engine. Thanks!
Darn,,, I am not allowed to post URLs because I have less than 10 posts. www(dot)youtube(dot)com/watch?v=VKHjUJk1F_Y
Followed your suggestion and it worked. The temperature went above 1000C for a few seconds before the GSU reads "Stabil" and the engine go to idle state. Strangely this time the exhaust nozzle didn't glow at all. Thanks guys!
Now I have another brand new P400 and got its thrust tested using loadcell sensor but apparently the sensor reading only showed 27kgf at max RPM (97,000). The generated thrust is no where near the described thrust of 40kgf. Can you tell me what did I do wrong this time? Does humidity affects the generated thrust as well because I live in Indonesia with tropical climate. Thanks!
