DLE20 - Throttle Problems
Probably should have mentioned that I reset the carb settings before I retested the engine. However, I will do so again to ensure the adjustments are where they are supposed to be.
My Feedback: (19)
Other than Rcexl, the other two common ignitions are CH (which also sells Rcexl) and RCAME sold mostly by RC Extreme Power under his RCXP branding. I've used them all with very good results. In some cases, I especially like the RCAME / RCXP ignition as it appears to have a bit hotter spark and a few other interesting features.
#31
IL
"This time, the idle is perfect, but upon acceleration, the engine quits."
Truckracer's question is legitimate. Don't assume for any reason that this carb is not going to need adjusting. Factory settings assure only that it's going to start. They do NOT provide any assurance it's going to run right after starting. That part is on you!
